The inner rotor of the oil pump has a flat spot on one side, and two teeth on the other. Does it matter how its oriented on crank? Two teeth on top of crank at TDC?
is this how I should seal the oil pump? I’m using permatex ultra gray. Hondabond is usually hard as a rock, brand new out of the package. I’m not really a fan of it, honesty.
I’m planning on laying a small bead of silicone as shown in the D16 instructions.
is this clean enough?
I’m not planning on greasing or oiling the o-ring that goes onto oil pump. I’m afraid it will mess up the silicone seal.
Thanks!
Thanks!
