1 - 10 of 10 Posts
yeah I know, lol but some headers fit all d-blocks so I just wasnt sure if it would fit.....fuck you.... lol j/k:)
CR-Vtakin
No more Honda's :-(
that oil pump will bolt on but you won't be able to check your oil. the dipstick tube on a z6 is in the block and on a y8 it goes in through the oil pump.
what i did was remove the gasket on the oil pump regulator. make sure to use some thread sealant on the threads when you put it back in. this "should" (i still haven't checked to see what i actually have for oil pressure) raise the pressure a bit. then i just ported the oil pump exit hole. the pick up hole is already the same size as the pickup.
1 - 10 of 10 Posts
