Honda
Does anyone know much about these Oil pumps.? Acl/Orbit Racing oil pumps.
Will they Supply More than enough oil for my Turbo set up?
do some reading
oem or go home
My stock unknown miles pump is running fine on my turbo set up. You could get a modded OEM pump from Endyn for peace of mind.
EG5T
New oem, ported if you have the $, or at least measured stock/used one and ported.
I had one and yeah there ok, didnt notice a difference from my stock, but it lasted. Before you go out and buy a new oil pump, fist make sure your engine isnt worn out and has good oil pressure.
Do they supply more oil? Well heres the thing, oil pumps DONT create oil pressure, they ONLY create flow, when oil gets picked up by the pump it travels were it needs to go, and before it exits, the "hole" gets smaller compared to the diameter of the tube were it was traveling, therefore it sprays like IF there was pressure... (imagine a water hose, and you placing your finger at the tip.. Pressure)So a worn out engine will have less oil pressure than a new/rebuilt one, no matter if you buy a 1M dollar oil pump
Black/Green Civic HB
A stock oil pump will get you far, if your not shooting for the moon.
I've run a stock oil pump for 60k, moving from 200hp to 285hp and never had a problem with oiling. Just make regular oil changes and watch your oil pressure
