1 - 20 of 67 Posts
im having some difficulty with my oil pressure.
at warm idle it fluctuates between 0.6 BAR and 0.0 BAR even when engine speed is constant.
cold start: 5.1 BAR
3000 RPM: 4.8 BAR
7000 RPM: 5.1 BAR
i sourced my turbo feed from my sandwhich plate next to my oil press sender and im not running a ressrictor as i have a bullseye, my press used to be 1.8 BAR.
any advice on this guys?
cheers.
luke.
it could......but its a good idea to not have any leaks in your oil system......
what has been done to it b4 the change in pressure?
i put a turbo kit on. i sorted the leak in the return line but its still dripping.
its a very consant drip and i think it mite be coming from the sandwhich plate.
it leaks enuf to almost empty the motor of oil in only a about 5 hours driving.
nope the OE light stays off the whole time.
i re did my feed line from the sender unit today and it seems to have steadied out at 0.8BAR.
i have been thinking about putting a restrictor in to the turbo?
its a bullseye so i dont need one but the lack of one is causing my pressure problems.
i changed feed sources for the turbo and its holding steady at 1 BAR (15 PSI) is that enough pressure?
1 - 20 of 67 Posts
