1 - 16 of 16 Posts
i spun a rod bearing in my old motor so i swapped the motor out and everything runs good but my oil pressure light is on.
i just replaced the oil pump, new pan gasket, and oil pickup.
i installed a autometer electronic oil pressure gauge and it sits and zero with engine running and the light is still on.
does anyone know what's going on, do i have a block/clog somewhere?
when i take the fill cap off with the engine running i can see oil spitting around inside but not spraying around.
well how much oil pressure is the guage readiing off idle? did u use teflon tape on the threads? i cant even tell you how many times ive seen gauges read improperly cause they arent grounded well. plus at idle oil pressure is very low that why i asked what it read above that at like 3000. did u prime the oil pump with oil when u put it in?
i did prime it.
used teflon tape.
ground is right off battery.
it reads at zero the whole time.
stock oil light is stedy on.
yes it's teed off the block and i used tape on the sensor before i changed te motor and it worked fine
take it back to whoever u bought it from, tell them that its fucked up and that u want your money back
well if its fucked up after replacing the pump, pick up and all that. would u still want it? i wouldnt.
fuck it. pull it and throw it through the peoples window and get your money back. or if u bought it form a shop or motor distributor tell them u want another one that works
well on the instructions it says to use teflon tape on the treads which i just did and i only hooked up the gauge and it sits on 0 when at idle and up in rpms
Discussion Starter #16
i pulled the oil cap off to see if oil was still flowing and the engine died, put the cap back on and it started right back up
1 - 16 of 16 Posts
