1 - 11 of 11 Posts
hey people,
well ive just pulled 1000 miles on my fully built Z6 and i think the oil pressure is running high.
cold start is 95-100 psi
warm idle (75 degrees) 23psi with idle at 900-1000rpm
IIRC warm idle should be 8-10psi?
cheers.
luke.
thats cool then, i just wanted to check before booking dyno time.
im just running 10w/40 mineral oil at the moment, will probally keep running it till 2000 miles then swap it out for some comma 10w/40 semi.
luke.
longs as you have the proper restrictor for the turbo
no restrictor!
how is oil going to damage a steel ring? it wont.
but if your drain is not up to the task, the oil might back up and leak out the tiny gap on the oil ring seal :bigok:
5w30 on a 206k miles motor
Hot idle @ 750 rpms = 20 psi
2500 rpms on the highway = 70 psi
cold start = 85 psi.
i am running a restrictor on this motor, when i had this setup on my stock the oil pressure took a big dive so i wanted to be on the safe side, i would rather junk my turbo then my motor.
i just running a recon'd oil pump, no mods to it.
luke.
1 - 11 of 11 Posts
