1 - 9 of 9 Posts
HONDA
ok so i go and electric oil pressure gauge intalled on the car. I have done the DIY oil pump porting and shimming.
so start the car gets up to normal opperating temp and drive the car. at 3500rpm the pressure is at 4 to 4.5 bar. but if i do a long pull say a 1st 2nd 3rd pullor a long 150km/h run on high way it pressure drops to about 3 bar at 3000 rpm when i slow down and cruise again. i though it might be coz i have gone into vtec and all the oil is sitting in the head but that doesn't make sence the more i think about it.
only thing left is heat. so it it normal for the oil pressure to do that?
HONDA
cool, thanks for the input. but is it normaly for it to change that much?
HONDA
true. cool thanks that puts my mind at easy a bit
If i can remember correctly Honda book says idle @ 10psi and 50psi @ 3krpm warm. My oil pump is ported/shimmed with 20psi @idle, and 70-80psi @ 3k rpm warm. Cold motor is a different story always 85+ psi for a bit. I'm using 10w30 oil in a newly rebuilt motor with spec bearing tolerances ^ for reference.
1 - 9 of 9 Posts
