1 - 11 of 11 Posts
My Car
Add a Y8 oil pump into the mix, then I think it could work.
That would be a try, but i already have the z6 pump. so i'll just stick w/ the steel pan.
The only thing different is the two studs that is on the bottom of the oil pump that hold the oil pan. They're offset a little further apart. Widen oil pan two hole where the oil pump stud goes through should do the trick.
My Car
The only thing different is the two stud that is on the bottom of the oil pump that hold the oil pan.
So you are saying, that i need to drill new holes for them to make it work ??
My Car
Edited above. Make sure to use the same pick up as the oil pan.
Gotcha. Thanks. The reason i was wanting to use the y8 pan is that i hate the steel pan gaskets. Even all the B setups, the gasket like to push out when tightening. With the y8, its that nice insert groove gasket!
1 - 11 of 11 Posts
