1 - 6 of 6 Posts
anyone know if i can put a 97 civic hx oil pan and oil pump on a d16z6 block. and the correct pickup tube. thanks for any input.
Honda Civic 4g4d
The pan I'm pretty sure it'll work. As far as the oil pump, I'm pretty sure it wont. The correct "pick up tube" would be for the oil pan. Always... I could be wrong about this but I'm pretty sure. I'm an ef-eg person. not sure about others.
the thing is that i need the hx oil pump because it has the crank sensor on it and i dont think the z6 pump has that.
i need the d16y5 oil pump and aluminum oil pan on a d16z6 and unless told otherwise i just dont think they are compatable. let me know if any of you have tried this combo i know its not goning to be common
1 - 6 of 6 Posts
