1 - 4 of 4 Posts
will a single cam zc oil pan fit on a d16y7? does it have to have P2E stamped on the oil pan to be a d16y7 pan?
the dip stick hole is in a different place.
sure it will work.. if you make it work.
if u try make sure to use the zc pickup
PS, there is more than 1 single cam zc.
its black and steel not aluminum. Also I was told the pan is from a d16y7 but P2E is not stamped anywere on it
1 - 4 of 4 Posts
