1 - 10 of 10 Posts
Ok, so I was going to change the oil after breaking in my turbo and I noticed a leak coming underneath the oil pan. At first I thought it was the oil drain plug but later I found out that the oil pan gasket was ripped.
Of course im going to have to get a brand new one but do you think if I use some gasket make to fill up the hole, it would hold?
Also how does a rip in the gasket like that even happen? I installed it properly because its been around 3 months since I did the job and had no leaks up until now. Any idea what could have caused it or maybe I did something wrong from my end.
Appreciate any help so this doesn't happen again. thanks
(left a picture attached of the rip)
Sloppy Jalopy
could have been too tight ,not correct torque sequence ,warped pan,shitty gasket..
pan needs to be removed can;t just rvt the outside.
had a similar thing happen to me this summer ,I blamed it on the gasket :)..
I torqued them to spec in a criss cross pattern form the outside to the middle of the pan.The gasket costed around 20$ so idk if the material was just very bad.
Guess ill have to redo it :)
Sloppy Jalopy
Sequence is middle to outside. Also make sure the metal spacers are still embedded into the gasket (not all holes have spacers), and double check your torque settings.
I have yet to see any of these spacers you speak of??
Discussion Starter · #8 ·
Yeah, I swapped those rings from the OEM gasket to the new one, supposedly it only had 2 if I remember correctly on the pulleys side. Its just crazy to me that such a huge can happen like that. Anyone have torque specs for these pan bolts just to make sure that the ones I use are correct (i used 9ft pounds)?
1 - 10 of 10 Posts
