1 - 4 of 4 Posts
d-series 007
if i get the stealth mode oil line kit for the 14b, is that all i need? will i have to buy fittings? will it fit right? anyone that has bought or used this should be able to answer that pretty simply....thanks
Jon
the hard-parker
it'll work and everything, but you might want to buy a sandwhich adapter for the oil feed at the oil filter. it's a bit of a pain to get it to work and everything. otherwise, you can get a feed at i believe the back of the block.
if you're going to use an aftermarket oil pressure gauge, then just plug into where the oil pressure switch is above the oil filter.
1 - 4 of 4 Posts
