1 - 3 of 3 Posts
Just curious, but when you guys run your lines, do you ever leave little J's in the lines? I figured if you did that, then when you shut the car off, all the oil wouldn't drain out and would keep the turbo wet for startup. The only hitch is that when you start it up, there would be an air pocket after the moment after the oil is pressurized before it gets to the turbo
*edit* I guess there's gonna be a little air even without the J just from the line being empty to begin with
1 - 3 of 3 Posts
