1 - 4 of 4 Posts
been recently noticed an oil leak coming from the side of my enigine by the egr valve.could this be the platic piece that is in by the valve and could this have an effect of my car lacking power with also the p1457 code?
98 Civic HX D16Y5
The oil leak is most likely your valve cover gasket/grommets along with your pvc("that plastic thing on your valve cover") and grommet.
Pics? We can help pin point your problem better.
As for P1457 that code is for EVAP system leak.
^^^get a new fuel cap! Specific to your car!
Love the Civic
Check your distributor oring and inner seal as well. They are close to that area, and can leak down to your transmission making you think it is other leaks.
ej8
Clean clean and clean it.
The baby powder it.
Start her up and go for quick ride around the block
Once it starts to leak it will clearly show.
But most likly its the valve cover gasket or dizzy oring.
Could be vtec gaskets (yes theres 2 up and lower) you didnt say if its vtec or not.
And p1457*
Is evap.
Check your hoses for the evap solniod and check your gas cap
1 - 4 of 4 Posts
