1 - 7 of 7 Posts
i took of my hot side and i had a good amount of oil in them. also, i had a small drip of oil coming from my muffler. my turbo has very very very very very little shaft play...if any.
at the same time my rings were done, there was also a small puddle of oil right outside the compressor wheel. the turbo also didnt spin at idle, but when i reved up, it started spinning like normal. since there is no shaft play, could me seals be done? is a rebuild necessary? my return line has a very slight kink in it but it will be fixed when the new motor goes in.
racist-bigot-sexist-homophob
Sounds like the seals were leaking.
1 - 7 of 7 Posts
