1 - 9 of 9 Posts
what does it mean when there is oil on the spark plug , and how do i fix it , and how much will it cost to fix ..its from d15b2 91 cex dx ..thanks
88 ED6
If it's in the well(top part); needs new grommet. i think like ~$15 for the kit(includes valve cover gasket and grommets).
Bottom(in the cylinder); either rings or valve seal.
it was on the electrode portion just on one plug ..so it would probably be the ring that needs to be replaced?..also how bad is it for the engine , and whats the worst that could happen while im driving w/ the oil leak on the plug
I think I have the same problem, someone please get back to us, I think its about the same as running on three cylinders. Its just bad over the long haul. 88rexsi do you have a bad idling problem too?
no it idles good but it hesitates a little while starting , other than that it ok..im just woried that i could damage something if i keep driving it ..and how much would it cost to fix ?....anyone
1 - 9 of 9 Posts
