1 - 7 of 7 Posts
93 sol and 91 civic
i have got a few obd0 sohc zc's from hmotors well i just got one in monday and the oil filter is smaller then all the others anyone know whats up if so do you have a part # cause having a hard time matching them up
Just buy the honda filters.. That fit all of the honda except S2000 or and NSX. They are all the same regardless if it is a 88 crx or and 06 odessey
You double posted this topic
I use the RSX oil filter on all my D's. Its the same size around but taller. I recommend the wix filter (napa gold) it's very good.
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=51356
I stopped using plastic (fram) oil filters after looking inside of a brand new one and seeing the bypass valve stuck open. Also, on a majority of cars the fram filters open up after only 2k miles leaving your entire oiling system unfiltered.
1 - 7 of 7 Posts
