1 - 20 of 36 Posts
Curious George
Do I need to put oil restrictor orifice with My T25 feeded from oil pressure sensor behind block, and what size of hose should I need ? I'll make it in rigid tubing like oem turbo'ed cars :)
thank you
Like i said in every other thread on this topic.
3an feed, 10an return, it's been proven to be ideal. Use only a braided feed line, you'll regret it if you use anything else, trust me, my car caught on fire from a cheap feed.
E
mark7901 said:
really depends on the turbo, I dont need a resitrictor because it comes with one internally......but you really need to talk to the turbo manufactor
even if it has a built in restrictor, that isn't enough. You should really get one for your oil line, if you want more peace of mind.
some times you need them sometimes you dont..
go buy one for 15 bucks and have it around if you need it..
i needed one on my dsm t25 but i know someone who does not use one and its fine.
just make sure your drain line is at least 5/8" i.d. i only use 3/4" id for my drains though..
The Master Fabricator
mark7901 said:
http://www.turbochargers.com/store/product_info.php?cPath=21_30&products_id=68
and I guess I should say the person who told me that is the person who warrenties the turbo. I didnt actualy talk to the "manufactor" per say
Yeah, they say no restrictor needed on a DSM... Our hondas have much higher oil pressure.
I have a 16G INSTALLED and running for almost 2000 miles... It NEEDS a Restrictor. I know there is a built in restrictor on the 16G, but it is not enough.
ok, I will definitly take your advise and triple check with this guy, but I specifically asked about it. I actually was talking with him for a while. He know's it's going on a Honda, I specifically asked him about the differences and he said I shouldnt have to worry about it. I will call him back. I'll also do some searches and find out the pressure difference in a 1g dsm vs. honda. Thanks for looking out! BTW, what size restrictor are you running on it? I would hope this guys doesnt want to replace too many turbo's by giving out that info.
1 - 20 of 36 Posts
