1 - 4 of 4 Posts
im replacign the timing belt pon a y5 block...the dumb dipstick is side mounted not liek my zc motor and its front of 2 lower timing belt cover bolts...how do i remove this dipstick or whatever? pull it all out anything...thanks guys
Yes you just have to pull it out. If I remember right there is a small o-ring that secures it in place. Just pull it out, I was able to pull it out a little bit and rotate it, then get to the bolts for the lower timing cover.
98 Civic EX
you can just rotate it out of the way of the timing cover bolts once you remove the one bolt that retains the dipstick tube.
1 - 4 of 4 Posts
