1 - 9 of 9 Posts
Hey all, I just put a new y8 into my 97 coupe and the guy claimed it only had about 70k on it.
When I start the car it runs good, I let it idle for a few minutes and then the car starts smoking. If I let the car sit for a few days and start it, no smoke for a few minutes but then it starts again
I pulled the head off and the pistons look good, but idk if it's rings, valves or what.
Some of the rockers have some play in it, but I have no idea.
There was a good about of oil coming out of the exhaust manifold at cylinder 2 and 3.
I'll include a picture.
Discussion Starter · #7 ·
Normally when it drips out the exhuast its the valves seal.
But also this will smoke right after idling then hitting the gas and normally goes away while cruising.
I hadn't gotten to drive it around due to I haven't finished working on it
Discussion Starter · #8 ·
I didn't even hit the gas on it; the pcv valve seems gunked up as well, so I'm going to replace the pcv, valve seals, and headgasket
1 - 9 of 9 Posts
