321 - 340 of 366 Posts
Infamous Kanjozoku hatch
Discussion Starter · #325 ·
08 H-D Ultra Classic
:hitit: :banana sex: :gayfight2:
Nice work!
Discussion Starter · #331 ·
it's all starting to make sense now..
lmao yep! sometime this week my friend James will come by to bypass the vtec since the vtec isn't working but still pulls pretty hard asf
Discussion Starter · #333 ·
Also Just bought me Digital Oil pressure gauge.
and AEM wideband with o2 sensor
Decide to fab for those gauges and block off plate on console.
and decide to switch it from top to bottom since I still have radio backet so I thought it'd be better if I placed it with radio bracket and surely it looks great!
Polish those panels up and put a shine to em.
Or do some scribe work on them!
Discussion Starter · #335 ·
Wrong person to ask about polish my rides seldom see high pressure water and almost never see soap.
I'm sure we have someone still lurking around that would have some good input.
Discussion Starter · #338 ·
My boy came back to soldering up the dizzy and wired up 2 gauges.
we bypass the vtec, it still doesnt pop a vtec so we suspected that I need o ring and dowell in middle of the head, I already order those so they should be here by 31th and hopefully I'll be able to pop a vtec and also the Oil pressure gauge read off, it read from 0-8 while its running which it supposed to be range in between 40-70?. It might be the reason from o ring/dowell if not the maybe my oil pump is weak?
any input on oil pressure reading issue?
Discussion Starter · #340 ·
so oil pressure is 0psi at idle and 8 at speed .?
try a known working gauge and sender before any more attempts ..
Oil pressure at 0-8psi while idling and about 19-40psi while driving. Those are brand new and I have no clue why its acting like that and I'm running lean as my wideband jump around..:poke:
