1 - 20 of 95 Posts
Lifetime Awesome Member
'89 CRX HF
This thread is dedicated to Forced Induction and N2O, and will have a list of the top 20 cars. This thread is not for posting projects or dyno racing. Pleas keep this thread clean from nick nack post so that it stays short and very easy to skim through.
RULES: These times will be street cars only, and by street cars I am going to use the IDRC/BOTI/NDRA/IMSTAR definition of street cars. Pretty much everything goes except the usual, No Plexiglass, No Fuel cells, No one piece front ends. The car does not need exhaust. This is not be corrupted by arguing about what a street car is or crying about exhaust/backseats/spare tires/ etc. This thread is no intended for track-only cars
This will also be a list of ACTIVE members of the site. Dont send me a PM when you just signed up or have no posts asking to be put on the list. If the members of this site dont recognize you, dont bother...General rule is at least 500 posts
PM me w/ a PIC of the time slip and list weight and engine code, then you will be added to the list. This is the only way to keep the list legit. Once your added feal free to post up pics/ setups/ ect so that other members can actually see what the fast guys are doing with there setups.If your name is not than please refrain from posts, , I would like to keep this a READ ONLY thread, if you have question for anyone on the list please use pm's. It will be alot easier to find the good info if we keep this thread as short as possible. If your setup is on the list and you post your setup, rather than make a new post if you go faster or change your setup please just go back and edit a post. This will help knowledge spread...
Forced Induction (turbo/supercharged/n2o)
1. JFK78 - D16Z6 EG hatch - 9.65 @ 153.82mph, 2200lbs
2. FarmYard, ED hatch a6/y8 2025lbs - 10.583 @ 137.00mph
3. danz - d16a6 - 90 cx hatch 2160lb - 10.912 @ 127.33mph
4. mike93eh, EG hatch, z6? 2360 - 10.938 @ 129.4mph
5. Hugo Boost - EG hatch, built a6/z6 - 11.16 @ 124.99mph
6. Chiovnidca, EF hatch, z6 2000lbs - 11.423 @ 131.11mph
7. DirtyDseriesWOOT, '97 Civic DX, 2600lbs - 11.433 @ 127.28mph
8. Boosted91, CRX, built z6 - 11.634 @ 118.92mph
9. 24-7, CRX, a6 1900lbs - 11.716 @ 115.44mph
10. kit88, 95 hatch w/ a6 block and d16z6 head - 12.246 at 114.50mph
11. AJXR, 90 DX hatch, a6 block z6 head 2230lbs - 12.275 @ 110.60mph
12. fjt, 99 hatch, built D16y7, 2600lbs, 12.44 @ 111mph
13. Y8pwrdEf, 92 EG sohc zc vtec, 2240lbs, 12.6 @ 111.08mph
14. ryan89crx, 89 HF, built no-tec a6, 12.86 @ 109mph
15. AMkrew_1, CRX - 12.9 @ 106mph
16. SnailedZ6, 1995 dx coupe, stock z6 - 13.188 @ 106.45mph
17. Y8pwrdEf, sohc zc vtec 2240 - 13.06 @ 108.17mph
This is a street car, though most of the comforts have been stripped out of it. It gets trailered to the track when running slicks but spends a lot more time stomping around town. :)
1991 std hatch
d16z6
eagle rods
srp pistons
garrett t3t04e 50trim
full 3" exhaust
10 point roll cage
racing seat and 5-point harness
si transmission
skunk2 drag launch springs
The best run was at 27psi on 110 octane cam2 pump gas. It spun the 22" inch slicks all the way through 3rd gear. With some 24.5" slicks and a track that's prepped better I hope to see some 10s this spring. :)
Here's my build thread: it has more details, pics, and a few vids.
http://www.d-series.org/forums/showthread.php?t=46521
same^^^
So, the list:
d15b bottom end
d16y5 vtec-e cyl head ported/3-angled/milled .028" (~10.4:1 CR)
OE gasket w/ arp's
skunk intake manifold w/ 60mm t/b & heatshield gasket
exedy performance clutch kit & 12lb. OE flywheel
dohc ZC trans w/ intermediate shaft
EG radiator w/ pusher slimfan
jimfab mounts and crossmember
Spare Room Products battery/cables/battery tray
subaru tdo4 wrx snail
CSaddict manifold
dsm 450's and BOV
2.5" downpipe/chargepipe
skyline rb25 intercooler(or so I was told)
obd-1/Crome/p28/zeitronix
mcmaster/summit/home depot oil lines
12.9 run in this video:
up next? Big cam, heatwrap, and weight reduction.
-josh-
1999 civic Hatchback
1999 Civic Hatchback
D16y7 motor
Stock Head with Z6 intake manifold
Stock cam,stock valvetrain, stock ports
Block:
Vitara pistons/Eagle rods
KMS Block guard
ARP head studs
Turbo:
T3 super 60 .48/060 cold side..flows 24lbs/min
LoveFab minime Manifold
Turbonetics Racegate(42mm) ..this was probaly hurting me a lot but ohh well.
3"DP and exhaust
Ebay Intercooler
DSM 450cc
Walbro 255lph
Tuned on Uberdata with a P06 ECU
Race weight: 2600lbs
Street tires--> 13.3 @ 112mph with 2.4 0-60ft
Slicks--> 12.44 @ 111mph with 1.8 0-60ft
Engine Shot:
Exterior:
Engine before putting it in the car
Time slip
I MISS HER!!!!!
EDIT22 X 8 X 13 slicks.. I dont remember the brand as they were borrowed from a friend on the track..These were the only 3-4 runs we ever did on the car on slicks so with more seat time the times coul improve..
Also the car was heavy at 2600lbs as the driver that night(not me) was 260lbs plus the car weight is 2340lbs. The car was ran with 93 octane and full interior, full exhaust. with me on it the car was around 2480lbs so thos 120lbs less made a whole lot defference on the street.
Im sure it could do 11's. i did ran an EVO at the street and pulled a car on him and the owner said the EVO was doing 11.8 @ 113mph.
Car had 266whp and 240lbs ft just revving it to 7000rpms since it was a non vtec stock head
I have the Video of the runs but i dont have a site to upload it.. I might try Youtube later tinight.
93 civic hatch
11.26 @ 125mph
110% street car. doesnt even have a cage and wont as long as its a street car. (i dont ahve to worry about rules at the tracks here) should be hitting 10's once i get to the track. car weighs around 2360 with me in it.
i dont feel like finding the timeslip but here is a video... this was from last november, pretty cold out. this was the first run of the day and was getting too anxious and only pulled a 1.69 sixty foot. i usually average 1.63.. i will be heading to the track here real soon for the 08 numbers :)
http://videos.streetfire.net/video/civic-hatch-1125125_141604.htm
formerly Kit88
ek hatch
Here is my time slip:
10 second daily driver :)
Update of mine
updated yet again
90 dx, 2230lbs, a6 block/z6 head
heres my time.. i spun bad at the launch.. i need slicks. but my MPH is up there.
with a 1.9 60 ft i think i can hit mid to low 13's
car is a 95 coupe with a z6. tuned on 10 pounds. bone stock besides that. :bowdown:
1995 coupe. stock z6 on 9-10 psi.
nitto drag radials. running 18 psi in them. launched at 5k rpm. and i had a LITTLE buit of wheel hope. but zero spin! i ran
13.188 @ 106.45 mph
but ill let the pictures show the proof.
my cars number
my new fastest time
1 - 20 of 95 Posts
