1 - 7 of 7 Posts
Wasn't sure if I should use the oem throw out bearing for my twin disc clutch? Its the clutchmasters one. Its making a weird noise when I let go of the clutch.... So that makes me think that it isn't the throw out bearing.
Foot off peddle is not the TOB, its ISB. (or just the normal noise from a twin disk)
So far there is 2 issues with using this clutch with my y8 transmission.
First, the oem tob plastic sticks out too far, and presses on the pressure plate forks, so this needs machined down... I just broke it out accidentally at first then I said fuck it and broke it out the rest of the way so it would clear...
Second, the bolts holding the plates together (allen head bolts) were rubbing a bolt on the inside of the transmission... I ground it down and now it works.
1 - 7 of 7 Posts
