I’m currently prepping to go boosted,from what I have read here I have a triple stage VTEC (two vtec solenoids!) which makes it a Z1 from a “VX”. My head cast numbers are (P2J-5) then the other two numbers are (95). I’ve looked this up and I found that this head comes on an automatic trans civic. I’m looking for the correct OEM part number for the double vtec solenoid gaskets,and where I can order/purchase them? Also,which OEM oil pump (#) do I use?
Thanks everyone ??
93 Civic HB SI
From your post, it seems like you are thinking the head might be different than what should be mated to your block? Is this correct? If so, why do you feel the head/block are different? What is the engine code on your block? Also, what market are you located in? Can you confirm the presence of two VTEC solenoids as part of the single assembly on the back of your head? It looks like this:
I'm not too familiar with that head/engine combo, as what I know about it those engines together as a combo that show 3 Stage VTEC in the list below and other searching around the net very quickly never made it to the USA. But that doesn't stop engine importers so it is possible to be had in the USA. This will make getting parts a bit different, but not impossible. Knowing what market you're located in will help guide people's recommendations to you.
A quick search on the D Series Wiki (https://en.wikipedia.org/wiki/Honda_D_engine) revealed this:
D15Z1
VTEC-E
Found in:
1992–1995 Honda Civic VX
1992–1995 Honda Civic VEi (European Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (2.95 in × 3.33 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Power : 90 hp (67.1 kW, 91.3 ps) at 5,600 rpm (92 hp at 5,500 rpm; USDM)
Torque : 98 lb·ft (13.5 kg/m, 133 Nm) at 4,800 rpm (97 lb·ft at 3,000 rpm; USDM)
Valvetrain : 12-/16-valve SOHC VTEC-E (USDM- Lean Burn Federal Emissions 49 State) (3-4 valves per cyl depending on engine speed)
VTEC Switchover : 2,500 rpm
Fuel Control : OBD-1 MPFI
ECU Code : P07
Head code: PO7-1
It seems that the head code for the D15Z1 is a P07, whereas you had P2J stamped which would make it more likely any of the following, specifically the ones that point out 3 stage VTEC as you stated you might have the 3 stage setup (VTEC-E is different from 3 Stage, as 3 stage combines VTEC-E and regular VTEC operations into one head):
D16Y5
VTEC-E
Found in :
1996–2000 Honda Civic HX
1996 Honda Civic EX (sedan Peruvian version)
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Rod Length: 137 mm
Rod/Stroke: 1.52
Compression: 9.4:1
Power: 115 hp (86 kW, 117 PS) at 5,600 rpm
Torque: 104 lb·ft (14.4 kg/m, 141 Nm) at 4,500 rpm
Valvetrain: SOHC VTEC-E (4 valves per cylinder)
Fuel Control: OBD-2 MPFI
Head Code: P2J
1996–2000 Honda Civic VTI
Compression: ?:?
Power: 127 hp (94.7 kW, 129 ps) at 5,800 rpm
Torque: 111 lb·ft (? kg/m, ? Nm) at ??? rpm
Head Code: P2J
ECU Code: P2N
Piston Code : P2MY
OR
D15B VTEC
3-stage VTEC
Found in:
1995–1998 Honda Civic Ferio Vi (EK3, Japanese market)
1999-2000 Honda Civic Vi-RS
Bore and Stroke :75,0×84,5 mm
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Power : 130 PS (96 kW; 128 hp) at 7000 rpm[8]
Torque: 139 Nm at 5300 rpm
Redline : 7200 rpm
Valvetrain : SOHC, four valves per cylinder
Connecting rod length : 137 mm
Connecting rod big end diameter : 48 mm
Fuel Control : OBD2b
Head Code : P2J-07
ECU Code: P2J (small case ECU)*** AUTO CVT: P2J-J63*** MT P2J-003*** & ***MT P2J-J11***
Piston code : P2J
OR
D15Z6
SOHC VTEC-E
Found in:
1995–2000 Honda Civic 1.5i LS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
114 PS (84 kW) at 6,500 rpm
Torque : 99 lb·ft (134 Nm) at 5,400 rpm
VTEC Switchover : depending on load, max ~3,500 rpm in 5th gear
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on engine speed)
Fuel Control : OBD-2a PGM-FI MPFI
Ecu Code : P2Y
Head Code : P2J
Redline : 6,800 rpm
Fuel cutout : 7,200 rpm
OR
D15Z7
3-stage VTEC
Found in:
1996–1999 Honda Civic VTi EK3 and Ferio Vi
Piston Code: P2J
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) at 7000 rpm
Torque : 102 lb·ft (14.2 kg/m, 139 Nm) at 5300 rpm
VTEC Switchover : 2800 and 5800 rpm
Fuel Control : OBD-2 MPFI
ECU Code : P2J
Manual Transmission ECU Codes : P2J-003 (OBD2a), P2J-J11 (OBD2b)
CVT Transmission ECU Codes : P2J-J61 (OBD2a), P2J-J71 (OBD2b)
Lean burn capable.
OR
D15Z8
VTEC-E
Found in:
1997–2000 Honda Civic LS (MB3, MB9), (European Market)
Rod Length : 137 mm
Deck Height : 207 mm
Compression : 9.6:1
Power : 114 hp (85.0 kW, 116 ps) at 6500 rpm
Torque : 95–99 lb·ft (13–14 kg/m, 128-134 Nm) :confirm? at 4500 rpm
Head Code : P2J P2M
ECU Code : P9L
VTEC Switchover : 4000 rpm
Valvetrain : SOHC VTEC-E, 4 valves per cylinder
OR
D16Y5
VTEC-E
Found in :
Rod Length: 137 mm
Rod/Stroke: 1.52
Compression: 9.4:1
Head Code: P2J
Compression: ?:?
Head Code: P2J
ECU Code: P2N
Piston Code : P2MY
Let us know where you are, and/or a bit more background into how that head may have found it's way onto your block if they are different. I'm curious about the specifics!
Thanks!
It would be far easier to remove the valvecover, and compare the appearance of the valvetrain to confirm what you have.
Hi I am currently in kind of the same situation and want to know what kind of head for sure I have. I think it's a complete jdm d15b because it says it on the block but my head reads p2j-3 with 97 in the corner. Is this a y5 head? I can take pictures of the valave train. I would appreciate any help
200whp for a GOOD tune and a COMPETENT driver and GOOD maintenance.
120-150whp if you dont give a shit about the car, but have a good tune.
Stay stock if you never pop the hood occasionally to check on things.
B-series Destroyer
4g 4d civic
All the PSI's!!!
