1 - 15 of 15 Posts
I am aware that it is best to build my engine with oem color coded bearings but here is the problem.... Taiho, Daido, and glacier vandervell all make bearings for honda but i know Glacier bearings are cheap but i cant find any of the others online.
Cliff.
Where can i get taiho or daido bearings....already checked hondaautomotiveparts.com, hondapartdeals, and slparts
If i cant get taiho or daido, should i just use GV bearings or go with ACL ?
Cliff.
Try your local dealer.
you'll never see GV's in anything I own, I'll run Clevite 77's before that.
Just a thought......the Y motors that are spinning rod bearings, wonder if they are GV's instead of Taiho/Daido.
from what i have heard they have a whole lot
I am not doubting that GV bearings are bad but i cant see why honda would sell them if they are. and plus i cant find taiho or daido for my 99 honda civic d16y7. and i want bearings that come in sizes. I just spent over 3 thounsand on this build and i dont want the bearings to fail.
i just found them not a problem...
13211-PG6-003 BEARING A, CONNECTING ROD (BLUE) (DAIDO) $9.48 $2.22
13212-PG6-003 BEARING B, CONNECTING ROD (BLACK) (DAIDO) $9.48 $2.22
13213-PG6-003 BEARING C, CONNECTING ROD (BROWN) (DAIDO) $9.48 $2.22
13214-PG6-003 BEARING D, CONNECTING ROD (GREEN) (DAIDO) $9.48 $2.22
13215-PG6-003 BEARING E, CONNECTING ROD (YELLOW) (DAIDO) $9.48 $2.22
13216-PG6-003 BEARING F, CONNECTING ROD (PINK) (DAIDO) $9.48 $2.22
13217-PG6-003 BEARING G, CONNECTING ROD (RED) (DAIDO) $9.48 $2.22
looking at the part numbers if you want a main from daido the middle part should be p2e.
for connecting rods its pg6
also looking on majestic's website they have all three listed, the part numbers above are from slhondaparts.com 1999 civic 4dr lx 5 speed
Lifetime Awesome Member
woohoo!! awesome!
wow after 5 years
Need help
Where I can buy connecting rod bearing (oem) , I need only yellow, green, green, pink for D16Y8.
I don't need big qty of every colour
Sry for my eng
and
TNX 4 answ
BR
1 - 15 of 15 Posts
