semi built block? how about a description of the build? your pistons should really be the deciding factor when trying to achieve a desired compressionlower, ill be boosting 10-13lbs through a semi built block, i know some people feel going with a thicker headgasket is risky so how thick would you go before stopping? Im going with cometic as far as quality
