1 - 3 of 3 Posts
I AM NOT RESPONSIBLE IF YOU DETONATE YOUR AIR BAG TRYING THIS MOD. I DO NOT ENDORSE OR PROMOTE ANY TYPE OF ILLEGAL USE OF EXPLOSIVES OUTSIDE OF LICENSED AND PROFESSIONAL WORK. DANGER, POSSIBLE CHANCE OF SERIOUS INJURY AND OR DEATH!!sorry for the lack of pictures in the process, but basically you
1) remove air bag
2) drill out rivets that hold cover onto mount
3) unscrew air bag mount from frame
4) re-rivet cover onto frame
5) dispose of air bag explosives safely....Im still soaking mine in water after Ive cut the plug wires off flush with the air bag
6) re-install
Retired From Hondas
you would want to dis connect the battery and let car sit for 15 mins before messing with the SRS system.
Theres also a capacitor you can use to keep the srs light off.
the oem wheel I had was removed from a vehicle late last month, I had a grant wheel in my car and hated it. and yes, your way works too, but I deleted the explosive charge that is the dangerous part. probably should put a caution note
1 - 3 of 3 Posts
