1 - 2 of 2 Posts
1. When I'm on the get-go, roughly around 4-5k I'm getting something like a grinding noise and when I hit the crossover for VTEC it's gone. It kind of sounds similar to that of the throw-out bearing in a manual tranny. I adjusted the valves last night .008 in intake, .01 in exhaust (only feeler guages I had) and It's still occuring.
2. Also, when i'm at WOT for a while I'm smelling something like gas inside the car. possible exhaust leak?
3. I get a huge puff of black smoke out the tail pipe when I hit the throttle for a good while. Is that normal?
As some of yall may now, I have an automatic mini-me swap-- z6 head with b7 bottom, h/i/e, virgin auto p28. running stock y7 cam gear. Too lazy to put on the AEM adjustable one. ignition timing set at 16* BTDC.
I'm also leaking oil from what looks like the rear main seal and/or dented oil pan.
J
I'd say your oil leak is possibly worse than what you think. Possibly causing a drop in oil pressure
(perhaps something internal)
1 - 2 of 2 Posts
