okay this coolant leak is driving me crazy. i have a 91 hatch. just put a 98zc d16y7 in it. used my old IM, TB, dizzy, alt, ecu, etc. Heres the problem.
when I start filling the coolant up, it leaks out the back. I cant seem to pinpoint it exactly but it seems to be coming from under the intake manifold by the thermo housing.
I replaced the thermo housing gasket, checked all the hoses and it still leaked. I thought for sure it was the o ring on the inlet pipe on the thermo side so i replaced that. I put a little rtv on it as lube so it wouldn't twist. It still leaked.
i thought maybe I put the intake mani gasket on wrong so i checked that and its good. still leaking. the intake mani gasket is for the 90 but that shouldn't matter right, since i'm using the old intake mani?
This is driving me crazy. where could it be coming from. Has anyone had this problem? any suggestions? It's not a slow leak either, it just runs right down the back and makes a massive puddle. Please help. And I did search, found a couple threads with similar problems, but I'm out of ideas.
