1 - 9 of 9 Posts
so im looking at converting my odb0 zc to odb1 and from my reserch it seems i need a specific dizzy ? from what i read it sounds like there is two different odb1 dizzys? does anyone have a pic comparing them ? or can i just use any odb1 dizzy ?
90 crx si/96 accord
I believe its a td43u dizzy...I got mine from distributor king off ebay....but that seller isn't around anymore unfortunately
Ok. It sounded more like you were putting it in an "EF" and converting to OBD1 from OBD0 is not something I generally support.
Im still trying to figure out all this converting form odb2 to odb1.
I know as far as the engine is concerned its my dizzy and the injectors .. i think
but converting the car im still working on .
nice blog btw
Questions , say i find a locale (canada nova scotia ) odb1 dizzy , could i use the plugs and stuff the guts from it in the odb0 case i have and make a working odb1 dizzy for my d16zc ?
also my will the plug work off my ek civic wirring harness with a odb1 dizzy ?
there are a few ways you can do it.. get a obd1 JDM zc dizzy like i have one my dohc zc swap. or do like i have done many times in the past and change the cam cap on the head the one that has the dizzy mounting point on it. put a LS cam cap on it and then you will be able to run a LS dizzy and gettin a OBD1 Ls dizzy is easy and if it fails you can get a quick replacment.
1 - 9 of 9 Posts
