Well?
So im looking at the TT high impedance injectors and it says you need to change the clips for OBDII vehicles? What exactly do i have to do? Also would the CBR injectors be plug and play no modding?
you need low impendence injectors 12 ohm iirc....then just the correct clips fpr the injectors
obd2 clips are different thats all
R2.....Zap Balls
94 Ex coupe
The clips just convert the plugs on your car to the style plug the inj take. They just plug in between the inj and factory harness
Well?
im trying to to wire a resistor box hence the high impedance plug and play
Well?
so basically get injector clips from an OBDI car and solder them ont my harness
