Hi,
Would like to ask if anyone could help identify make/model of the connector pins from the picture?
vernier measured approx dimensions:
a. smaller pin connector
length - 25.3mm
body width - 1.7mm
pin width - 1mm
b. larger pin connector
length - 23.6mm
body width - 2.5mm
pin width - 1.5mm
thanks in advance
They all bent and broke when you tried to plug it in? Pretty normal I hate those jumper harnesses. Good luck searching for your pin part numbers.
no they aren't broken actually am gonna convert it to obd2b to obd2b so i need to make additional terminals. i depin it so i can visually see what it looks like when i check for it online.
Go find an OEM harness somewhere. Theres gotta be at least 1 other Honda in a junk yard around there.
Discussion Starter · #5 ·
i have a obd2b harness set and non of the pins are compatible.
thanks for the input btw
