everything should work what map is on the ecu?
It would be the z6, all of those chips are the same. They put out a lot of timing and to much fuel, if it was crome or uber then you could put your own basemaps on it and get it running the way you want...i'm not sure what the base map is, i'm guessing z6 but it has a moded skunk2 chip.
