1 - 2 of 2 Posts
I am building a turbo setup on a car that I am doing a mini me swap.
My del sol is a 97 so it is OBD2 has a D16Y7 that I am swapping the head on to D16y8. I also ordered a hondata s300 in a p28.
My question. I am wanting to spend some money on some new injectors that are saturated so I won't need a resistor box. Since I am doing this with an OBD1 ecu, would I need to get injectors with OBD2 adapters or do I not need adapters.
See this pic for reference. Would I need those wiring adapters or not, It is cheaper if I order just the injectors.
All stock and most aftermarket obd1 and obd2 injectors are Saturated. Yes you will need the adapter plugs to use obd1 injectors with the obd2 plugs if you want it plug and play. You could all so cut the obd2 injector plugs off and solder obd1 plugs on,I'm not a fan of this. One last thing you can do is swap the engine harness for an obd1 harness.
You will all so need an ecu step down harness to use the obd1 p28 ecu in the obd2 97 del sol.
1 - 2 of 2 Posts
