This might be a kinda noob question but can you use an obd 1 distributor with an obd 0 computer?
workinprog · Registered same as above Joined Aug 30, 2006 · 1,084 Posts Discussion Starter · #1 · Dec 17, 2006 Only show this user This might be a kinda noob question but can you use an obd 1 distributor with an obd 0 computer?
transzex · Brokedick Millionaire Joined Dec 13, 2003 · 40,970 Posts #2 · Dec 17, 2006 Only show this user no.
workinprog · Registered same as above Joined Aug 30, 2006 · 1,084 Posts Discussion Starter · #3 · Dec 17, 2006 Only show this user What obd1 ecu do i need?
si-hatch86 · OMG TOTALLY COOL TITLE!!!! 88 y49 crx Joined Aug 16, 2006 · 3,918 Posts #4 · Dec 17, 2006 Only show this user are you gonna run vtec or anything like that? u can use the p28 or a chipped p06
workinprog · Registered same as above Joined Aug 30, 2006 · 1,084 Posts Discussion Starter · #5 · Dec 17, 2006 Only show this user is the p28 the stock ecu they use for the d15b ?yes ill be running vtec
si-hatch86 · OMG TOTALLY COOL TITLE!!!! 88 y49 crx Joined Aug 16, 2006 · 3,918 Posts #6 · Dec 17, 2006 Only show this user you can use the p28 for the d15b. its used for the z6 also.
