G
·Aight i'm a newbie so BARE with me...what the [email protected]#k does OBD1 and OBD2 mean?????? My engine is a d16y7...which one do i have??? And whats the difference...is one faster then the other or wat??? thanx.
Just make sure the conversion harness he gets is an OBDIIb to OBDI !!zac said:so if he wants to convert his 2000 y8 to obd1 he has to get a conversion harness and the ecu from a 95ex right but keep his cars engine wiring harness??
If you open up your ECU, and look right next to the "Chip", you'll see a component marked "J1". This is a jumper to enable the "chip" section of the circuit board. If you cut this jumper, the ECU will return to stock, and ignore all the "chip" stuff on the board. In the OBD1 ECUs, when you chip them, the stock program stays on the board, and the J1 jumper enables the "chip".Toddnos said:...the one I bought isnt virgin, and it dosent work right.
Who knows what it is chipped for........Turbo? Nitrous? who knows. Now in addition to the cost of the ecu, i have to pay for it to be re chipped.
WOW!!! I never knew that........Im gonna go hometoday and open up the ECU. Thanks for the info!!!........will this cause any damage to the ecu, or future chipping capabilities?Jaker said:If you open up your ECU, and look right next to the "Chip", you'll see a component marked "J1". This is a jumper to enable the "chip" section of the circuit board. If you cut this jumper, the ECU will return to stock, and ignore all the "chip" stuff on the board. In the OBD1 ECUs, when you chip them, the stock program stays on the board, and the J1 jumper enables the "chip".Toddnos said:...the one I bought isnt virgin, and it dosent work right.
