1 - 11 of 11 Posts
Honda ;)
Hi all,
I have some questions because I need the information tomorrow.
We have a OBD1 car, and an OBD0 engine.
I wonder, can I use the OBD0 engine wire and ecu with OBD1 interior harnass?
Or do i need to change some stuff?
1.8 nawz powa
obd0 bay harness will not work what an obd1 interior/chasis/cabin harness
you can run an obd0 motor with a obd1 bay harness and just switch the dizzy out
Honda ;)
Okay thanks!
Well i need to find the obd1 engine wire, well i know where it is but i still need to get it.
update:
btw, i only need to swap the distributor ?
'95 EDM Civic D14Z6
Greetings.
Probably, due to head layout, you'll still have to use OBD0 distributor, just needing to change pin-outs on the distributor.
Some Civics are 2 earpoints, others 3, so each head needs to use its own distributor. Motor is OBD0, use OBD0, use the search button to find OBD pinouts, and change the plug.
dodo-upgrades.nl might help, also.
raimundo please stop dude.
swap out your obd0 dizzy for a obd1 (like one from a d15b7 or so..)
then use the obd1 harness and wire everything up.
i know for a fact this works.. im using a obd1 harness, a obd1 dizzy on a obd0 motor lol.
racist-bigot-sexist-homophob
Greetings.
This is why some people are better off not posting.
1 - 11 of 11 Posts
