1 - 12 of 12 Posts
I'm a lot of people with obd0 have thought about this or maybe there not even aware that there's programs to tune obd0.
OBD0 Has just had a huge makeover and it works excellent. There's IAT and ECT enrichment. I haven't had a chance to use it, so I can't say how well that works. RTP and Datalogging work great and are easy to use. There's rev limit, target idle, code disable, etc.
OBD1, crome in particular as I haven't really messed with any other obd1 programs does have a few features TE doesn't. like the ability to choose the tps% that you go into open loop, gear fuel trim, injector voltage, and some other advance stuff. but in general I find it a little less user friendly.
Members on here have tuned 300 horse on TE. My personal car runs great on TE.
Anybody else have any other comments that have used both??
1993 Cobra
I have messed with almost all of the tuning software out and i keep coming back saying that crome is the best. Crome is what i started out on so i guess that has something to do with it. I find it very user friendly, it pretty much explains what your looking at in the advanced tables. TE uses some weird numbering for fueling. Plus, OBD-1 is about as close as OBD2 smart-ness as you can get without having to use piggy-backs.
TE uses injector on time ( aka, duty cycle, milliseconds, pulse width). What the hell are the numbers in crome??? I still haven't figured that out.
2001 Z3 Coupe 3.0i
I recently donated to fastcrxsi90 and TurboEdit. I'm hoping a new true dual-map vtec plugin for TE with a PM6 will be coming out soon. I'd like to be able to just use OBD0 for my A6/Y8 mini-me without all the expense of OBD1 conversion.
Been thinking of me & chris lately? OBD-1 converts...
Yeah, and that ryan and others are running. I've stuck with it as with my knowledge, which I'm trying to learn more, haven't had a problem with TE. My cars not dialed in because of the lack of time I actually spend on it, not because its TE.
2001 Z3 Coupe 3.0i
Hmm. It looks like it had problems and it was left with them. I'll have to just give it a try.
ive used both and i find ectune with obd1 is leaps and bounds better then TE.
how ever, its also much more expensive.
my car ran boosted for about a year and a half on obd0 with TE and never had a problem. for the price, TE is the SHIT! :) (in a good way, of course, lol)
Lifetime Awesome Member
'89 CRX HF
my use with TE was relatively limited. i did use it on 2 different turbo setups of my own, but both were pretty low hp setups. it was also years ago, long before the new developments with it.
as far as Crome goes, i have NO issues with it. tons of little extras to play with, injector scaling for almost every injector on the market, FTL, 3-step, FTS, etc. etc.
i honestly would never go back to obd0 unless it was a new project that was on a serious budget.
i also have a full version of Ectune on my laptop that i will be using to tune a friend's setup. ive only played with it a bit but man does it look nice! ill give some input on that in a month or so, after i play with it
D-Series Destruction Master
you win at posting
1 - 12 of 12 Posts
