1 - 14 of 14 Posts
Hey, need some help about converting my engine / D16Z5 / to obd1, what are my options for ECU and distributor :roll:
Are all obd1 distrubutors will work or need to be from DOHC engine?
Will VTEC distributor work on non-VTEC engine / have some spare from my old B16/ ?
made any attempt to search?
Discussion Starter · #4 ·
gtpilot - for better tune options
slo_eg8 - yes, but couldn't find anything which can help me or maybe my search is not good
Discussion Starter · #5 ·
Continue searching and I found that ZC DOHC OBD1 92-95 TD43U Distributor probably will do the job.
Is there any other obd1 Dizzy that bolts up the DOHC head , cause this one is not common in my land
ED6&7. EE4&5, MB1
Just order the TD43U, it's the correct one so it fits and works best.
Distributor is not the place where you want a hack job solution.
Discussion Starter · #8 ·
Didn't found any used, so probably these is my chance -
ebay.com/itm/191410327024?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Not oem but guess no other option?
97 EJ6 boosted D16Z6
Turbo edit is for tuning obdO. Might save you some hassle.
\/Your Mom Was Here\/
Vibe GT
It more or less will depend on what your tuner is comfortable with. There are a few on here that will argue about obd0 being superior for tuning and vice versa. If your tuner is reputable and works with a certain program than I wouldn't tell you to go a different route.
Thanks but known that obd1 ecu is more accurate for tune than obd0
You should do some reading up on turbo edit if you believe that.
1 - 14 of 14 Posts
