okay so i have an 88 civic converted obd-1 with p28 and d15b. i want to learn how to tune using crome. but my first problem is getting everything that i need for datalogging. im wondering what the innovate lm-2 would plug into on my car. so im trying to figure out everything i need and what it does.
thanks
moates.net
pgm-fi.org
Lc-1 will work fine. I have a friend running a jaw it works ok and is cheaper. I run a lm-2 it is nice but I tune more then one car.
so how does an lm-2 read all of my sensors like map and temp sensor? my cars stock dash harness doesnt have obd port or w/e. thats kind of where im stuck. would using hulog to datalog and emulator to tune then chip burner to burn map, be just as good?
What you do is data log with freelog, cromepro, neptune, ectune, hondata. Using data from inside the ecu using a hulog,hondalog of the 4 pin header cn2 inside the ecu.
The lm2 monitors voltage out side the ecu by taping into the tp,map........wires then you view that data in log works 3 innovates dataloger, it is not live but a recording. The lm2 has a wide band out put wire you would tap this into the stock o2 sensor wire and output a wide band signal to view in a internal ecu loger.
Ya read a lot more Hondata - Honda ECU Modification and Enhancement has a lot of info to. Same with xenos site.
The way I do it using turboedit is to use the cn2 port(serial port) on the ecu through innovate's logworks application. It should work the same for you on crome. logworks has a plugin for the open source serial port logging that turboedit and crome both use, and interfaces with my innovate wideband on a separate channel.
I use 2 serial port adapters on my laptop, one for the ECU datalogging through a moates hulog, and the other serial port is for the LM-1 wideband. Logworks then takes care of the details, collecting the data from both serial channels and combines them into one coherent log i can tune with that includes all the ecu parameters and the wideband data.
It is a little clutery with 2 serial port adapters, but it works great.
