i am converting my 97 civic hb to obd 1 for tuning purposes
i was told that after i use the conversion harness that i have to re-wire the tps sensor and change over the 02 sensor to 4 wire
any one ever run into this , any help would be great
joe griffin
I've heard a lot of crazy things like that, you should be able to use a conversion harness and bypass everything else, nothing major changes with OBD2 except that it is tougher on emissions and stuff like that.
OK since this is brought up i've heard the only way to do this swap with an auto car is to change more then just the ecu. the trans,etc. why is that? Why wouldn't it be just like a stick swap and just an ecu change?
