1 - 4 of 4 Posts
Hi guys and gals. Just purchased a 1998 DX HB d16y7. The guy i bought it off of installed a stock header from an ex due to the original header cracking he connected one 02 sensor and disconnected the other. My question is how do i determine which plug is for the primary and the secondary? i want to be sure it is hooked up correctly when i get the full exhaust system in a couple of days. one plug wire looks longer than the other but was not sure if that was the deciding factor. i will get a pic up of the engine bay asap.
easy way without looking is not plug one in and check the CEL code for which one is unplugged with no 5vt heater source connected
Thats a good way to do it. However in my 98 DX I know the longer one is the downstream O2 sensor. You could arrange them like that to start with then check them as posted above if you have problems.
1 - 4 of 4 Posts
