1 - 10 of 10 Posts
ive done some research and know what i have to do to notch my block
but im wondering if anyone has any measurements to notch the girdle?
my pistons are oversized so im boring the block and they wont fit in the bore now to test fit the rod bolt clearence.
im thinking maybe just installing the rods with no pistons to test, unless anyone has any other suggestions.
im using eagle h beams with 3/4 arp bolts
and i was going to get my machine shop to assemble my block so i wanted to notch the block and girdle before i brought it to them
i used eagles as well and i just used a die grinder until they had enough clearance. just be careful of the oil gallie on the girdle where cylinder 2 is cause u'll be grinding right below it and if u hit it, ur screwed....unless u got another girdle but then ud have to align-bore it and all that happy horse shit...goodluck
EK 96
Is not much . I have the same RODS and notch the botttom for clearance.
1 - 10 of 10 Posts
