1 - 9 of 9 Posts
Hey guys new here.
I've been planning a build on my D16Y8 i have currently with 210k miles, planning on rebuilding and going turbo.
Now with that being said and a lot of reading i've done i see that for example with Vitara rods you have to notch the block.
With that in mind i was wondering what options are there out there for forged rods that would not require notching the block. Or if i have a misconception regarding this and notching is only required in certain cases.
Thank you :D
notch it and be done with it.
2000 Civic Hatch EJ6
Even with the Skunky rods built for the vitara's, you need to notch the block. There's a good write up on notching with plenty of pictures showing how much to notch. Only took me an afternoon. In most cases you'll need to notch the girdle as well.
There are no "good" rods that fit D16 blocks without notching. You need to do it, and its not a big deal.
Just drop a piston on the rod, no rings. Slam the old bearings in the block, slam the old bearings in a rod, drop it all in, torque it down to what ever you want, and spin it over. Its not a big deal at all.
Discussion Starter · #5 ·
I know it's a not a big deal and i don't mind doing it if i have to, just wanted to get my facts straight before i jump in lol. But thanks, i think i know what i'll be doing next month now :D
Theres alot of banging slamming and dropping here, do you work on FORDs for a living?
Fords aren't so bad! Unless you expect the timing chains and guides to last. :)
Crower rods don't require notching
On D16's? I've had a few D15s that didnt need notching. But if so, cool good to know too bad they are like $800!
1 - 9 of 9 Posts
