1 - 17 of 17 Posts
Seeing as I'm an awkward sod, I've got my Z6 bottom end bored and honed + notched out for my Eagle/Arias combo.
And my Y7 head has been ported.
Now, I know I need to use a Y7 timing belt, and I'll be using a Y8 heagasket, but what ARP head studs would I need to use?And in what order!?
Another question you might need to be answered...Are there any modifications needed to make the non vtec head run on a vtec block? I have never seen a no-tec head ran on a vtec block. Thats just me.
peterbilt
does this lower compression?
he is running a non vtec head.
I'm not yet sure about any mods that need to be done.Maybe something to do with that oil jet?But I dont think I'll need to do anything, hopefully.
Z6 and Y7 head have the same combustion chamber size, so no compression change.
Not that it matters because I'm using low comp Arias pistons anyhoo.
I've done this a long time ago. b2 head on a z6. all you have to do is add the oil jet to the block. and I've always read you use the timing from the head and it's worked for me, I couldn't tell you technically why, block heights and timing belt length required for X height...
so get y7/y8 arp head studs
y7/y8 timing belt , not 100% sure there the same
and put the oil jet in the block.
if your putting it in a EK chassis your going to throw a code if your not using the Crank fluctuation sensor. so you'd ether have to use a y7/y8 oil pump or slice into the crank angle sensor single for the ecu's
no oil jet is needed to be added to the block, its under the center cam holder in the head.
it looks like your putting it in a ek chassis though. your going to have a problem if you don't use the y7/y8 oil pump. this is the same issue I'm going to have deal with. I hate hacking up the stock wiring unless it absolutely necessary. so I'll probably modify the y8 pump ( port it a little) and run the fluctuation sensor.
Where's the fluctution sensor on the Z6 block?
I don't particularly want to use the Y series pumps at all lol.
If its a case of extending some wires I don't mind that!
Just had another thought...
Would I be best off using a Z6 cam gear to time this up as opposed to the Y7/8 one?
assuming our going to boost it, the sensor doesn't matter. since it eliminated during the obd2 to obd1 conversion.
Ahhh...is it now,that'll do me nicely then.
Of course I'm boosting it...It'd be rude not to after I've shelled out for headwork,Bisi turbo cam and Arias low comp pistons!
1 - 17 of 17 Posts
