1 - 2 of 2 Posts
ok i just recently bought a 95 honda accord 2.2 vtec for a work car for my wife. i need to change the front brake rotors and i am having a problem. the front rotors on this car are part of a hub/bearing assembly, where you have to take four bolts out from behind the knuckle to release the assembly off the knuckle and then to replace the rotor you have to unbolt the hub and bearing assembly from the rotor (there are four bolts that go through the hub and thread into the rotor) i cannot get these four bolts out. the head of the bolt is so small that when i put a socket on the bolt only like1/4" goes into the socket so i can't get any leverage without the worry of rounding the bolts. you guys have any ideas for how to get these out? i also tried a 1/2" impact with no luck!
1 - 2 of 2 Posts
