98 civic
well i have finally figured out my project. im gonna do a B20 bottom with a B16 or B18c head. i have been reading around and have come to a question that i haven't really got a answer to yet.
what ECU would i need to use on this? P28?
would this setup be good for boost or a N/A setup?
i know i have to move a dowel pins but to where? i have heard to the opposite side of the the cam gear side. is this correct?
and how do i get the oil pressure to flow to the VTEC system? would taping into something work to get it going?
thanks guys
Honesty if your asking this many questions you need to research it some more. It's really more of an N/A setup, but will work with boost. Running a P28 will be fine, and for the oil pressure look into the Golden Eagle kit to take care of that.
98 civic
well this is things that i have found different answers to. i found a book online that i just ordered that has a part about doing this swap so ill know what i need to do.
98 civic
i will most likely get it chipped and tuned. and i just found out about the dowel pins i was correct about have to have them moved to the opposite side.
