1 - 20 of 30 Posts
Lifetime Awesome Member
'89 CRX HF
Well i finally got around to installing my Walbro 255 yesterday. before i buttoned everything up, i cycled the key about 10 times to make sure the pump would prime and there was no leaking fuel. but when i went to start it, it fired up then died and i got a solid CEL. then the fuel pump would not prime at all. found the Alternator purge fuse blown, replaced it, car fired up yet again, then died with the same problem. i replaced the factory 10amp fuse with a 15amp, and havent had a problem since(although i only have 15 miles on it so far)
is this normal?
Although i've never heard of this before, a 15 amp fuse shouldnt hurt anything. It might just be drawing a little more amperage than your factory pump. :TU:
I've heard the stock gauge wires get a little hot, so I wouldn't be surprised if the fuse isn't happy.
88 ED6
My cousin had a similar problem, but his turned out to be loose wiring(although he said it was his ECU fuse that kept blowing).
2000 Honda Civic EX
I did not need a bigger fuse when I installed mine.
R2.....Zap Balls
94 Ex coupe
10 second daily driver :)
make sure all your grounds are clean. any rust or corrosion can up the impedance. but going from a 10 to a 15 isn't that big of a deal.
i've installed a 255 in my crx. did not have to change the fuse. but i would agree a 15 prob isn't a problem. if there is a real problem like a short its't gonna blow what ever you got in there anyways. maybe weak connection somewhere?
[email protected]:noway:
FAMILY MEMBER #316
i didnt have to replace my fuse but again, it was in a 99 ej so maybe they used thicker gauge wiring as compared to your dinosaur crx?
also i did write up on a current draw test
power=voltage x current
i dont know what wattage a 255lph pump consumes but if you know that and its supply voltage (13.5-14.4v) then you can calculate your expected current consumption and change fuses accordingly.
del Sol si '94
put the 10 amp fuse back in, relay + hotwire = happy pumping
Any diy links for this? If not Ill make one. Mine Walbro is on the way!
98 civic
also no pump variations with the turn signals......
lol mine does that lol it took me about 2 mins to wonder wtf mate why is my pump doing that
1 - 20 of 30 Posts
