1 - 11 of 11 Posts
Just finally decided to join after lurking around for a while and looking for information here and there. I am from Anniston, Alabama and have a 93 civic dx with the d16z6 in it. I acquired the car from my brother that had a ls swap with a 18g turbo on it after he blew it up on 15psi . Needless to say he wasn't thrilled that his old car now would have a SOHC in it lol. The z6 was rebuilt with srp PM6 9.5:1 pistons, eagle h beam rods, golden eagle head studs, supertech blockguard, comp cams valve springs with new valves, brian crower springs and retainers. I am stuck on a dilemma on which cam to run and if I want to use a aftermarket intake manifold or not. Also Of course has all new bearings, water pump, timing set, gaskets, seals etc. Has intake, header and full exhaust ,coilovers and rota rb 4x100 +25 offset wheels. Car is a little peppy for being a sohc with the mods and the s20 or p20 b000 transmission which ever you go by. Ill try to post a pic of it sometime tomorrow when im not at work. Plan is to make 250-300whp later from a turbo setup.
Welcome to the forum! Plenty of info on cams and intake manifolds here among other things, I'm sure you'll find what your looking for.
\/Your Mom Was Here\/
Vibe GT
Sounds like a soild setup. Colt cams has great customer service and stand behind a great warranty as well. The one cam I wouldn't run is a Bisimoto, other than that most the others are pretty decent.
You can always start a showcase thread if you want to show progress on the car with some pics of the work and parts being installed.
Love the Civic
Welcome, in for moar pics or showcase.
All the work is already done and car is running sorry didn't take any build pics...ill post some pics sometime this week of the way I got the car and what it is now...Lets just say this is a hardcore weight reduction car , my brother decided just about everything needed to come out lol
Retired From Hondas
Car looks pretty clean and the single jingle in it can handle some boost if you wanted to go that route..
Goal is going to be 250-300whp on the setup in the car. I have already started accumulating other parts that will be needed for this .
it needs to be redone but yes I love that color and it will go back to that color
1 - 11 of 11 Posts
