1 - 20 of 20 Posts
So I have a 98 coupe with a d16y8 and just decided to boost. I have a parts list made up and am just wondering if im missing anything or should change anything up.
Walboro 255
dsm 440s
fuel pressure regulator
P28 with a base tune
noname turbo mani & downpipes
boost & air fuel ratio gauge
Hks seqq bov
Dsm 16g turbo
skunk 2 intake mani
Ls throttle body
ebay hard piping kit
srt4 intercooler
Exedy Stg 2 clutch
New engine gasket set
+ .40 over vitara low comp pistons
arp rod bolts
arp head studs
new bearing kit
Ebay adj cam gear
And crower has a stage 2 turbo vtec cam
If im missing anything or should swap parts for something else PLEASEEE let me know and thanks in advance everyone!
adds displacement- faster spool time/ fresh hone/ bore. de-shrouds the valves better . draw back more prone to detonation. weaker dsleeves in theory
--- I would get rid of the air fuel gauge and get a real wideband with gauge. pressure regulator isnt needed unless your maxing out the injectors and you compensate by upping pressure a bit. no name mani? (get a cast iron if so). crower T-2 eh too much lift IMO its more of a top end built drag purpose only cam. i would look into a delta 272 or bisi 2.4 better. i would get a real cam gear if you plan to use one and that also isnt really needed unless you milled your head too much
I also have no head work done, is that going to be a problem..have an estimate on what power that would put down?
stock head is good for 400hp // fuel rail// IM . for a stage 2 cam its suggested and recommended you at least get upgraded valve springs.
Ok thanks for the input and ill look not the different cams and turbo mani, is there anything else im missing besides oils lines and stuff like that?
If you have to ask what your missing, than your not ready to tackle such a task as building a turbo engine. Knowing absolutely what your doing is critical in a successful turbo build. Because with most parts you only get one shot at it befor you have to repurchase the same part.
Reason im asking is to learn. I wont lean everything I need to know by looking at forums so im going to take everyones advice and then learn by doing.
And i was hoping to get away with stock rods
d series rods are super weak. i'm not a 100% but i think they are good to maybe 200hp.
with 440cc injectors maybe 280hp on a ify tune if your turbo can throw down
i think the 16g max's out around 330 or something
oh and grab a B20 tb if you can there 60mm fuck the skunk2 just match port your stock intake save some money and have one less part some stupid fuck wants to steal
Walboro 255
dsm 440s
Hks seqq bov
Dsm 16g turbo
skunk 2 intake mani
Ls throttle body
srt4 intercooler
Exedy Stg 2 clutch
arp rod bolts
arp head studs
new bearing kit
Ebay adj cam gear
If your going to do a rebuild and take everything aparts I would suggest pistons and rods. Better safe then sorry and that way if you ever want more you don't have to worry about the bottom end strength giving out
Discussion Starter #16
So I guess ill throw a set of rods in with my build:)
Does this forum site have a market place? Sorry guys im super new here
Gotta have 65 posts before they let you in.
We have site sponsors and you could contact almost any one of them for good deals on rods or even rod/piston combo deals. Goautoworks,fjt, and rcautoworks just to name a few of them. All have great feed back and willing to help. I have person experience with Greg at Goautoworks great guy and is always willing to help.
1 - 20 of 20 Posts
